Palette functionality changed in version 8.5
When using LabVIEW 8.5, I have not found a way to disable the "personalized menu" feature for the palettes. That requires me to click on the expand menu arrows then navigate to the palette item I wish to select nearly every time I use the palettes to drop system vi's. This is very frustrating as I am a LabVIEW program now for 12 years, and this is the first new "feature" which has slowed my programming. I'm sure there is a way to disable the roll up for the menus, does anyone know how?
In version 8.2 I used palette settings Format: "Catagory (Standard)", Navigation buttons: "Icons only", I would like to have the same palette structure
(3,138 Views)
Hey HTC,
Just fix the palette (using the Pin) and you will get:
Customize Palette View
From there you can customize your palette view as you like.
Christian
(3,126 Views)
Hi Christian,
Perfect! That is even better than before !
Thanks, HTC
(3,112 Views)
