Palindromic Numbers Consisting of the Product of Two 3-digit Numbers
@jcarmody wrote:
I'm in the high 30's, now...
That's the best I was able to get. 3 ms is sure hard to beat 🙂
Ben64
Message 11 of 29
(2,151 Views)
I cut it in half. 🙂  I wonder if the string conversion is the bottleneck?
Jim
Message 12 of 29
(2,139 Views)
I was using string conversion too. The rest of the code just needs to be a little smarter. 🙂
Message 13 of 29
(2,124 Views)
I made it.
Jim
Message 14 of 29
(2,115 Views)
@jcarmody wrote:
I made it.
I guess you should go back to the drawing board. On a more modern computer mine is well below 0.8ms (now on a 3.1GHz CPU, most likley even faster on a current generation CPU). Only using one core.
Remember, the 3ms was on an ancient laptop. 😄
Message 15 of 29
(2,100 Views)
I was happy to do better than brute-force.
Jim
Message 16 of 29
(2,082 Views)
I'm hitting 0.22 ms (single core) by observing that all 6 digit palindromes are multiples of 11, by not using string compare, not bothing to do a palindrome check for any products smaller than my currently largest product, and by starting from 999 and working backwards.
Message 17 of 29
(2,048 Views)
@Oligarlicky wrote:
I'm hitting 0.22 ms (single core) by observing that all 6 digit palindromes are multiples of 11,....
Ah, did not know that. OK, if I include that test, mine drops to 0.12ms (Still using string compare, though)  😄
Message 18 of 29
(2,041 Views)
@Oligarlicky wrote:
[...] by observing that all 6 digit palindromes are multiples of 11 [...]
That's what I was waiting for.
Jim
Message 19 of 29
(2,032 Views)
I'm noticing some weird stuff depending on how I benchmark. If I stick it all in a for loop I can hit ~2 ns/ itteration. To be fair, I'm only doing 256 palindrome checks in my search (everything else gets filtered out).
Message 20 of 29
(1,978 Views)
