Palm E2 MemoryMgr.c,Line:3751 Data Log VI
I get  Fatal Alert -  MemeoryMgr.c, Line:3751, Free Handle when code that opens a Datalog file executes on Palm Tungston E2.
(3,710 Views)
Can you post a simple, hardware-independent version of your code which reproduces the problem?  This sounds like a bug, and if it is, I would like to reproduce it so I can forward the problem and code to R&D to be addressed for a future version of LabVIEW.
Thank you,
JLS
Best,
JLS
Sixclear
(3,704 Views)
I  too get  Fatal Alert -  MemeoryMgr.c, Line:3751, Free Handle when code that opens a Datalog file executes on Palm Tungston E2.
after several test, i finish by understand. I use the vi PDA memory usage.vi and i look the palm memory increased always.
then i use PDA memory compact.vi  for  free the memory but after test the vi don't operate.
I use this vi on  an other palm (T5 and T3)and it is good.
(3,638 Views)
Interesting, so the problem seems to be tied to that PDA, and now it seems like you cannot execute that VI at all - can you be more specific about what you mean by "but after test the vi don't operate"?  Is the VI broken or does it simply crash when executing?  I didn't find any documentation specifically linking the Tungston E2 model to problems.  But if you could post some code that you used to reproduce it, and perhaps a screenshot of relevant error messages, warnings, or anything else which might help, I'll gladly look into this more!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,632 Views)
