Panel Frontal of VI
Hello everyone. Sorry, we could send screenshots of the front panel of the following files vi?
For some reason I can not open in Labview 8.5, despite having been converted to this version.
Attached is the original files which I believe are in the version 8.6 or later.
Thanks.
(2,608 Views)
Here you go.  They are LabVIEW 8.6.  If you need them downconverted in the future, there is a thread for that.  Make sure you mention they contain IMAQ code.
(2,564 Views)
Hello DFGRAY. Sorry for the inconvenience, but it happens that for some strange reason I can not load the file converted to the version VI 8.5 (in the respective post and was converted from 8.6 to 8.5) with LabVIEW 8.5 (I have the installed vdm and imaq usb) that is why you resorted to in order to obtain images of the front panel and block diagram.
I take this opportunity to ask them to image the block diagram of the file even CAMARA.VI, they are greatly appreciated.
(2,542 Views)
