Paralel loops and serial communication
Can you please convert the VI to 2011 format Smiley Surprised
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 29
(2,221 Views)
@TimBotsM wrote:
However while keep thinking over his post I'm wondering if it would be a "good design" to send with the command (to the serial parser) also a reference to the queue used in the transmitted loop.
Yes! That's one good way to do it. That way, you can use the same subVI for all of the devices. Here's a not-too-clean example:
Message 12 of 29
(2,213 Views)
Why this two consecutive VISA read ?
--Ranjeet
Message 13 of 29
(2,209 Views)
the backbone of my testrack is an RS485 bus, so if I send data I recive the data as well.
I updated the VI and this is how it looks.
So now I'm wondering: would something like this be a good design?
The VI is attached in 2011 format.
Message 14 of 29
(2,199 Views)
Friend TimBotsM
                         In RS485 Communication its not necessary if you send data then compulsory you will read response. Nothing like this is defined in the RS485 standard. But mostly Tx and Rx both will be active but not necessary
My question is why this two consecutive VISA read ?
--Ranjeet
Message 15 of 29
(2,196 Views)
Nothing wrong with that. It leaves you in good shape to modify the tx/rx loop (term-char, different nBytes, etc.) without having to change the message sender.
The bits to clean up will be (at least):
1) Deciding how to stop the multiple loops. "Release Queue", somewhere, will cause an error on enqueue and on dequeue. I've heard that called "scuttling the queue".
2) Dequeue timeout stalling the command loop. Scuttling the queue will solve this, but the data coming out of the dequeue will be an empty string.
3) Scuttling the rx/tx loop's command queue will cause the VISA write/read/read to happen again.
Message 16 of 29
(2,188 Views)
As he said - the backbone of my testrack is an RS485 bus, so if I send data I recive the data as well.
In that I said its not compulsory thats it.
I am not saying code is wrong or not optimized, What is my question is why this two consecutive VISA read. I am not talking about queue at all.
--Ranjeet
Message 17 of 29
(2,183 Views)
I replied to his question about the code, not to your question about reads. It doesn't bother me that he needs to read the echo.
Message 18 of 29
(2,178 Views)
Friend Todd_Lesher,
                              My mistake, carry on. I thought you are replying me.
--Ranjeet
Message 19 of 29
(2,173 Views)
@Ranjeet_Singh Since I use an RS485 bus combined with an FTDI chip I allways get an echo (TX is connected to RX hardware wise). So I need a way to get rid of this echo.
The way I see it I have 2 options
  1. read 16 caracters and split the string
  2. do 2 reads of 8 characters
If I do the 2nd there is a small advantage that if it reads 0 characters on the 1st read I know there is no bus connected and if there is 0 characters on the 2nd read there is no device connected (also a timeout)
@Todd_Lesher I'm using the "Queued Message Handler" design patern. So in order to stop all the loops I put in the "exit" string and all the loops should release their queue and stop. If one of the loops enters the "exit" state they'll queue an "exit" (whitout error check) command to the main handler, is the main is already gone, fine, if not, this will stop all the other loops.
I guess with Scuttling you mean something to dump the queue. The "Queued Message Handler" design patern should do the same.
Message 20 of 29
(2,169 Views)
