Parallel InPort Status Register in Windows 2000
I cannot read Parallel Port Status Register
(LabVIEW 6i 02 and Windows 2000). I tried all the NI solutions; CVI AccessHW, ParallelNT. I have tried all the parallel port configurations (EPP, ECP, Normal . . ). I Need Help.
Thanks!
Harold Hebert
National Research Council Canada
(3,041 Views)
Hi Harold
try to use the attached test vi - on my NT & W2k machine it works o.k. Do you have in addition to accesshw the system.llb filled with In Port / Out port for NT+W2k ? - (including their sub.vi's).
In case of questions mail me - address find in vi's
hope it helps - regards
wha
(3,041 Views)
HI
i want write data to print port use "out port.vi", but not ok.
that has a error "wase stopped at node 0X1BC of subVi out port.vi", why?
now i use "outport byte to port.vi" can write data to parallel port, but clock not ok.
can you tell me how to control parallel port clock rate?
mail to me : tedlai@tmsinc.com.tw
TKS
Ted
(3,041 Views)
