Parallel Port
I've been asked to try to send a simple signal (such as an ascii character) to a device via a parallel port, does anyone know how that can be accomplished via labview?
(3,376 Views)
The NI Appication note: Using the Parallel Port in LabVIEW should have all the information you need. Good luck!
(3,376 Views)
Hello �
Here is another useful document that might help you get started:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/configuring-serial-and-parallel-...
S Vences
(3,376 Views)
