Parallel port digital i/o
I have a circuitry where I am trying to read the output of a ADC. This requires 8 pins (D0-D7) of the parallel port. Besides this, I also need to send logic 1s (and 0s) to a series of other chips to enable or select their individual functions. For this purpose, I require another 7 pins of the parallel port. I hope someone can answer my doubts about whether which pins of the parallel port (other than 18-25 which are ground pins) that I should or not use. Pins 2-9 are reserved for the data to be received by the parallel port from the ADC.
How can I individually state which pins I need to send logic 1 and which to send logic 0? Please advise. I've looked through almost all the questions (and their solutions) posted but none matches my require
ments. I am using LabWindows/CVI 5 and Win 98.
(3,080 Views)
hi,
find lot's of suggestions on jan axelsons website;
http://www.jaxelson@lvr.com/ - for LabVIEW you find some hints on your previous question.
Regards
wha
(3,080 Views)
You may find the following useful:-
http://www.advmeas.com/goodies/parallelport.html
NI Application note 062
Also remember to link pins 10, 11, 12 & 25 on the 25-way D
Good luck Keith
(3,080 Views)
