Parameterized query format for select statement
Perhaps try taking the carriage returns out of the SQL select statement.....
Message 21 of 27
(1,976 Views)
Just tried it with no carriage returns - just one line.  I get the same error.
Message 22 of 27
(1,973 Views)
Are you sure that your first column name is a valid name?
Try to remove that from the SQL statement..
Message 23 of 27
(1,962 Views)
Good call.  So the column name can't begin with a number?
Message 24 of 27
(1,959 Views)
It appears that the @ symbol is not needed if you are accessing an Access 2016 database.  It also appears that enclosing the parameter in the sql statement isn't a must.  I don't know if this is true for earlier versions of Access.  These parameterized Access 2016 database queries work for me.  It appears that my problem was starting a column name with a number.  Also, I believe if the column name has spaces in it, you need to put the column name in square brackets (e.g. [First Sample ID]).
Thanks everyone for the help and for posting the initial solution.  I would still be trying to figure this out if it wasn't for the help.
Message 25 of 27
(1,951 Views)
Sorry for the multiple posts.
Even this works with parameterized sql queries to Access 2016 databases.ParamQueryFinal.JPG
Message 26 of 27
(1,928 Views)
One of the things to remember is that parameterized queries are not standardized between platforms: everyone does it different​ and as in the case of Microsoft can change it at anytime.
Certified LabVIEW Architect
LabVIEW Champion
Message 27 of 27
(1,918 Views)
