Parent VI recompile. When and why?
When parent VI is going to recompile itself due to changes in child VI, and when it is not?
(2,596 Views)
Look here.  it was the second hit on a google search using this term: labview when does vi recompile
Bill
CLD
(Mid-Level minion.)
(2,594 Views)
To add "why":
The compiled code also contains a section called "inplaceness information". This section tells the caller (parent VI) if a parameter can be passed by reference (no copy) or by value (copy).
If changes in the subVIs can effect the way parameters are handled, the caller has to re-evaluate the inplaceness info, hence, it has to re-compile.
Norbert
Norbert
Expert: Geometry
(2,565 Views)
Another thing just coming up in my mind:
If it is of concern for you that re-compilation of the caller (parent) changes the .vi-file so it has to be saved on disk again, you should use the option to separate compiled code from the vi-file.
Norbert
Norbert
Expert: Geometry
(2,543 Views)
