Parent VI won't let me run two VIs at the same time.
So I have one PC connected to a CompactRio 9030 and a cDAQ 9174. The Compactrio is running a NI 9503 to power a stepper motor and the cDAQ 9174 is running a NI 9237 to read a load cell.
I can get readings from the load cell, and can get the motor to run. However I use two different VIs that belong to their own LabVIEW projects to run each. The motor and load cell have their own VIs. I can only run one at a time, when I run one VI the other front panel is "frozen" and I can't interact with it. I wrote a program to attempt to run both VIs at the same time.
I tried to follow this format
http://digital.ni.com/public.nsf/allkb/498AFF045628DFA9862571D10079672F
However the program doesn't work and throws an error. I'm pretty new to LabView and any help would be great. Thank you!
(4,249 Views)
Accepted by topic author KevinPn
What are the window appearance settings. For example is one set to "modal"?
(4,226 Views)
Yes I think one of the window setting is set to modal. Heres a screenshot of the settings. Untitled1.png
(4,219 Views)
(4,187 Views)
More questions:
What type of projects are these two vi in?
Are one of them a Real-time vi, that is part of a RT project and located under the RT target in the project?
Show us your projects, and files.
Are your question releated?
https://forums.ni.com/t5/LabVIEW/Can-I-use-a-CompactRio-9030-with-a-NI-9503-while-using-a-cDAQ/m-p/3...
(4,179 Views)
For some reason one of the VIs was set to modal. I changed it to default and it works now. Thank you!
(4,137 Views)
Makes sense. A modal window will plant itself frontmost and will not allow interactions with other windows until it's closed.
(4,133 Views)
