Parse letters from numbers
Hi, I have to parse the letters out of a string to just get the numbers. I have four cases (just using filler numbers for this), so I have-
Vbatt: 0.15V
Ichgin: 0.15A
Ichgin: 0.15A
Ibatt: 0.15A
and I want just 0.15 as an output string. How do I approach this for all different cases?
Thanks in advance
(3,620 Views)
For each line, parse the substring after ":"
(3,619 Views)
You can do it with a single Scan from String.  Read the Detailed Help for this function (drop the function on the Block Diagram, select it, and choose Help).
Bob Schor
(3,602 Views)
It wasn't clear if "I have four cases" means that each scan is one of the four or if we get the entire four-line string at once, differing only in the numerics between successive scans.
(3,600 Views)
The following regular expression would work:
([\d\.]+)
If you want to also extract the units, you could use the expression:
([\d\.]+)(\w)
(3,569 Views)
Here's probably what Bob had in mind:
(3,565 Views)
