Parsing 2-D Array into Inverte Matrix error with Local Variabel
Hallo Community,
sorry for the banality of my question. I want to invert a Matrix.  I feed the invert matrix function with a local variable that is feeded throw a 2 D matrix. I have looked the process throw probes up and concluded that the Inverse matrix function spits a [0x0] matrix out. Could someone show me what i have done wrong :0
thanks for your help !!!
(3,564 Views)
Did you put valid data into your controls?
Right now all your controls are set at default values, including 0 for Array ?? control going to the N terminal of the For Loop.  If I put a meaningful value in there like 2, it works.  Anything else fails because you have hard coded inside that loop a 1-D array of 2 elements, so you wind up with a rectangular array that you can't invert.
(3,521 Views)
  • Remove the delays
  • remove the local variable and branch the wire going to the blue array indicator
  • Remove the sequence structure, it makes no sense.
  • You can only invert a square 2D array (or matrix), so your code only works if "Array Größe"=2.
  • Create a DBL array directly
  • Avoid coercion dots
  • You can enter error=-20040 into "menu..help..explain error" and it will tell you that "Analysis:  The input matrix must be a square matrix."
(3,518 Views)
Try something like this:
(3,514 Views)
