Parsing data from serial port into Arrays
I've tried changing the range increment, min, max, multiplier with the case statement abv but nothing seems to work... i cannot spread out the high frequnecy waveforms....
Message 21 of 33
(2,951 Views)
ghostz,
You've asked the same question in several threads and on different boards. That is considered 'bad' behavior. Why don't you pick one thread, post your code, and be a little patient in waiting for an answer
Message 22 of 33
(2,946 Views)
Hey Eric,
I'm manually setting the X-axis range in the properties instead of using a knob with the property node and it works fine. Problem is when i pass in a 35Hz sine signal it appears like this. Is it possible labview visa or waveform chart cannot deal with the data speed? I require to send signals with frequencies of interest up to 100Hz which is why I'm sampling at a rate of 250Hz.. satisfies the nyquist theorem so the problem shouldnt be aliasing?
Dennis: Sorry abt that. Din know abt that rule.... I tot it was fine to ask a few ppl the question... point noted... I'll stick to this thread from now on... Smiley Sad
Gerard
Message Edited by ghostz13 on 03-12-2007 10:46 PM
Message 23 of 33
(2,943 Views)
Gerard:
I am still not sure about why you are experiencing such issues plotting your data. 35 Hz is not too high of a frequency for LabVIEW, I am curious to find out how you are sending your data to the plot. Please post your VI so that I can help you further.
Rudi N.
Message 24 of 33
(2,924 Views)
Hi Rudi,
I increased my sampling rate up to 2500Hz and the problem still occur. The signal distorts above 10Hz. I'm connecting a function generator to the pin A0 of my pic16f877 (with internal 10 bit ADC) and sending it over by com port to my PC after using a max233 to convert ttl to rs232 voltage levels. The pic converts the voltage level to thousands of millivolts and sends it over in the format XXXX<CR>.
The Vi checks for data in the buffer, seperates the string with <CR> and plots the waveform.
Attached is my VI. Thanks for helping....
Plot
Gerard
Message Edited by ghostz13 on 03-14-2007 07:15 AM
Message 25 of 33
(2,916 Views)
Gerard:
 I did not see your VI ...
Rudi N.
Message 26 of 33
(2,900 Views)
Why do you make is so hard? You can attach a file to your post by simply clicking the Browse button right below this message body. Right where it says "Attachment".
Message 27 of 33
(2,900 Views)
Din realise there was an attachment upload for the forum itself.. Heres the vi...
Message 28 of 33
(2,888 Views)
Gerard:
Sorry about the late reply. Are you still experiencing this issue? Please let me know.
Rudi N.
Message 29 of 33
(2,797 Views)
Hi Rudi,
I've found the problem. Apparantly the microcontroller is not outputting data as fast as i expected hence aliasing problem. So i did a serial interrupt driver on the pic side to reduce the lag and I managed to get a sampling of 200Hz, the min needed (cos i have a low pass filter cutoff 100Hz), the signal can be seen roughly so I'm not gonna touch this project anymore.. Thanks for ya help!
Gerard
Message 30 of 33
(2,785 Views)
