Parsing string into channels input
Hello
I am attempting to parse a String into a matrix or arrays in real time. So, assuming the line below is part of my input
A134B932C321D95E532F1024A13B932C321D95E532F1024
I would like to parse the data and continously create a matrix (or series of arrays) such that each row corresponds to a letter. For example something like below:
13 13
932 932
321 321
95 95
532 532
1024 1024
I have been able to parse the string using the letters as delimiters but I have not been able to find a way to organize the values. The overall goal of my project is to be recieving 6 different input from a mircoprocessor and displaying the inputs on different graphs.
Thank you in advance,
Message 1 of 22
(4,829 Views)
If you show what you have done so far, then it is much easier for someone to be able to help you the rest of the way.
Message 2 of 22
(4,817 Views)
In LabVIEW a matrix is a special type of array and is used only for certain mathematical operations which are defined on matrices.  You want standard LV arrays.
Your string starts A134... but you parse it as 13.  A typographical error?
Please post what you have tried with a typical input string saved as default.  It is much easier for us to see what you have accomplished and help you toward a solution.
Lynn
Message 3 of 22
(4,816 Views)
Is the channel count fixed?
TailOfGon
Certified LabVIEW Architect 2013
Message 4 of 22
(4,805 Views)
Hello
The A134 and parse 13 was a typographical error.
I have attached a image of my block diagram in labivew. Currently I am able to slipt based on the letter but unable to group all of the same letter together. The amount of channels will be constant (in this case 6 inputs).
Message 5 of 22
(4,801 Views)
Set your default data type for the conversion to array to be a 1-D array.  Then on every iteration of the while loop, build that 1-D array into a 2-D array that you store in a shift register.
Message 6 of 22
(4,797 Views)
You can use a regex. There will be an extra blank element you have to handle if you do it this way,either with a case structure or trimming the array..
Message 7 of 22
(4,785 Views)
Ooops, I forgot to show what Raven's suggested, using build array to make the 2D array. But, building an array with a shift register is fairly basic.
Message 8 of 22
(4,764 Views)
I agree with Greg, regex is the best way to handle such a string manipulation. I like my regex to be very specific. (I heard that the more specific, the faster it executes) Here is another way. This ensures that which index belongs to which channel.
TailOfGon
Message 9 of 22
(4,761 Views)
Hey
I created the recommended shift register and my block diagram can be seen below. However, my input in the array is getting shifted. The inputs are variable values, and as a result I need the parsing to "detect" which letter it is and add value in the correct row or column. I am unsure what change I need to make in order to determine which row each value should go into.
Thanks for all your help so far. 🙂
Message 10 of 22
(4,754 Views)
