Parsing strings.
I have this string as below:
0xABCDEFAB #LADKJF
0XAABBCCDD #ADKF
0XAABBCCDD
How can I strip out everything
except for the hex numbers, ie.:
ABCDEFAB
AABBCCDD
AABBCCDD
I've tried it for the whole afternoon.
But no luck. Can anyone help?
Van
Message 1 of 9
(5,875 Views)
> 0xABCDEFAB #LADKJF
> 0XAABBCCDD #ADKF
> 0XAABBCCDD
> ABCDEFAB
> AABBCCDD
> AABBCCDD
Hmm, "Spreadsheet string to Array" with as separator. Then "Scan
From String" with format string "0%[xX]%x". This will as second
parameter actually return an 32bit integer, representing the value of
the hexadecimal string.
Included image shows two possible ways actually. Watch out to enable "\
code Display" for the string constants.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 2 of 9
(5,873 Views)
Thank you Rolf,
You came through for me again.
Much appreciated.
Van
Message 3 of 9
(5,873 Views)
I have a simular problem that I have been working on for a couple days. I have a string that looks like this
+7.50000000E+01 F,101,+7.50000000E+01 F,102,+7.50000000E+01 F,103,+7.50000000E+01 VDC,104
I want to search the string for a channel number (i.e. 102 ect.) an parse  the reading (+7.50000000E+01 F) less the (F) convert from fract/exp string to number and place it into a 1D array. I have tied the example "extract numbers.vi" and was able to get all the number out of the string but it did't preserve the exp values i.e. it read 7.5 instead of 75.
I'm greatful for any help,
jb112454
Message 4 of 9
(5,688 Views)
The attached vi proposes two different solutions. Hope one will fit your needs
Chilly Charly    (aka CC)
Message 5 of 9
(5,674 Views)
That works great. I didn't realize that you could do that so simply. I need to do more programming not just when we need something. Again thanks so much. jb112454
Message 6 of 9
(5,654 Views)
Hi
I'm trying to parse a string and seperate it into
String
Number
String
The only problem is that the output is not delimited by a special character (, ; : ! - _ or anything of the sort).
An example would be
B43F
whereas another example would be J
I could also have 102443H
and so on...
The amount of chars is random so is the offset. So basically, is there a function that can scan a string and differrentiate a number from a string.
I've tried the scan function
e.g
B43F
With Scan function and %s I guess, B43F
e.g
43F with Scan function and (double) I get 43 and F. This works!
Thanks again!
Message 7 of 9
(5,168 Views)
Use %[^0-9]%d%s for your format.  The %[^0-9] takes a string up until, but not including, a decimal character.
Message 8 of 9
(5,151 Views)
Thanks.
I'll try that!
I was reading up on those format strings but couldn't quite understnad how to use it.
Message 9 of 9
(5,146 Views)
