Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Parsing text files
Parsing text files
pblue
Member
06-03-2001
06:24 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have written a vi that parses data out of text files which makes use of the open text file vi. When I compile the vi to run as a stand alone application, The open file dialogue will only accept .vi files for opening. Why is this?
Russ T.
0
Kudos
Message
1
of 2
(2,785 Views)
Reply
Re: Parsing text files
Shan Pin Koh
Member
06-04-2001
01:15 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Without looking into your program, I am going to guess the following:
If you are using Open/Create/Replace File.vi, wire in "*.txt" to Pattern.
Hope that helps.
Shan Pin Koh
Systems Engineer
Oakriver Technology
0
Kudos
Message
2
of 2
(2,785 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
