Particle in 2D Box - Central Force?
I was trying to replace your random number initial position with a defined initial position but somehow it doesn't work. Do you know why?
Message 11 of 18
(1,523 Views)
I follow your suggestions to do the collison problem, but somehow my codes don't work. Basically, I say that when the particle position vector equal to each other, their velocities have to flip the sign.
Message 12 of 18
(1,516 Views)
That code makes no sense at all. All you get back is the original array control, possibly truncated to 4 elements. The FOR loop is not needed.
Note that the lower array contains the speed components, not positions.
Message 13 of 18
(1,504 Views)
Please keep the code scalable, you need to detect collisions between all particles, no matter how many there are.
"Delete from array" is not the right tool to split an array. Also remember that is is virtually impossible for two infinitely small particles to occupy the same space at the same time, so your comparison will never, ever be equal.
You would need to define a finite particle size. Collision detection would need quite different code and either trajectories need to caclulated with a much finer time resolution or you would need a much more intelligent geometric algorithm. You also need to consider the direction of each particle and how close the two trajectories are, etc.
Message 14 of 18
(1,498 Views)
Oh, and just for kicks a quickly made a 3D version. as I said, minimal code changes! 😄
Message 15 of 18
(1,490 Views)
When I try to replace your 3d position vector, which is generated by random number, with my 3d defined position vector, I find that I can't make my vector default in this code. Namely, when I have column vector 8 8 8 -1 -1 -1 7 7 7 and I make this to be default. Next time, I opened the same VI and all the vector become this, which is attached.
Message 16 of 18
(1,455 Views)
Are you defining the default for the array or the default for the array element. It depends what you select or where you right-click. Done correctly, this should work just fine.
Maybe select all the array controls followed by "edit...make selected values default". Now save the VI.
Message 17 of 18
(1,444 Views)
Your suggestion works, thanks!
Message 18 of 18
(1,434 Views)
