Pass an array of strings to a Visual C dll
I have to pass an array of strings to a Visual C dll. The array is obtained by the build array function in Labview 7.1. The problem is that the strings in the dll are wrong: at the end of each string there are some additional and undesidered character.
Can anyone help me ?
(2,796 Views)
Filippo;
Could you provide more information on how are you building the array in LabVIEW? You can take a snapshot of your diagram and post it.
Also, check the following article:Passing a Variety of Data Types from DLL to LabVIEW.
Regards;
Enrique
www.vartortech.com
(2,790 Views)
Thank you Enrique and sorry for my english.
When I pass to the dll an array of strings with the same length, the strings in the dll are correct.
There is a problem when I pass an array of strings with different lenght (see attachment ViAndDll.jpg).
Filippo
(2,781 Views)
