Pass array to Eval Formula Node (any chance to avoid this?)
No, there is no such option in 7.1 verison 😕
Message 11 of 19
(1,178 Views)
I've corrected some mistakes. And here it's now available for use in LabView 7.1. (attached VI) Thank you!
Message Edited by ACiDuser on 05-24-2009 03:45 PM
Message 12 of 19
(1,175 Views)
Sorry about the "multiply vs add" compound node confusion. I forgot to set the mode to multiply after placing it. 😉
Some additional comments:
  • multiplication is commutative, so the multiplication with Fm should be done once outside the loop. Use my code directly, but change the mode of the compound node from "add" to "multiply", of course.
  • The "zero" diagram constant should be DBL to avoid coercion (just enter 0.0 to turn it orange)
  • If you make the function an enum instead of a ring, the case structure will show the item name, thus avoiding coding mistakes.
  • Why do you have the front panel maximized to the screen? There is not really much on it. This gives me tunnel vision! 😄
Message 13 of 19
(1,169 Views)
Thanks for the tips! 🙂 Now here's the last version:
Message 14 of 19
(1,157 Views)
I have built a VI Function for this purpose, so now it's usable very easy
Message 15 of 19
(1,147 Views)
Indeed. altenbach likes to make things easy on people. Smiley Wink
Tip: You can use the Ramp Pattern VI to create your time values rather than the loop in the bottom left.
Message 16 of 19
(1,129 Views)
In addition, we can do all multiplications on the scalars, thus making ~N times fewer operations before the loop. 🙂
Also, the sampling frequency should probably be DBL. Why restrict it to integers?
Here's how if would look like using "ramp pattern".
Depending on what you want, you should round up or down to get N.
(It is possible that the ramp pattern looks slightly different in LabVIEW 7.1).
Message Edited by altenbach on 05-25-2009 10:32 AM
Message 17 of 19
(1,123 Views)
Thank you very much! Your suggestions are professional as always! 🙂
 Now I hurry up to re-design other my VI's, which will perform much faster and optimized!
Message 18 of 19
(1,112 Views)
Here is re-designed version.
Message 19 of 19
(1,109 Views)
