Pass data back to calling VB from built LV App
First, let me say I know there are other options, but due to certain constraints I'd like to pass data back to Visual Basic from a built LabVIEW application (EXE).
Visual Basic is calling the LV app EXE and passing values through the command line.
Does anyone know a technique that would be able to return data to the calling VB application?  Maybe stdout?
Thanks!
(2,634 Views)
how about a custom made dll (which sits in LV application )that will pass the data back to VB?
Or you can even write the value to a file and read the same in VB later (offcorse i do not recommend this since unnecessary file operations are involved)
Guru
Regards
Guru (CLA)
(2,624 Views)
If you want to build a single file with a VB top level, I agree with Guru, create a shared library (DLL) that you can call from VB.
Check out the LabVIEW Help files on how to create Shared Libraries
(2,611 Views)
