Pass from Python list to strings or elements of Labview
Good day to all. Help me please. I get the Python array in Labview by TCP IP. I need to build a graph on the elements of the array, but I do not know how to do it. Very little experience. Tell me please. The array consists of 100 elements. Elements are a parameter's value.
(5,155 Views)
what is the format of your received string?
do you know how to parse strings into labview's data formats?
do you know how to graph stuff in labview?
attach an example vi of what you have tried already,
with example data, so we can run it.
i think the best format coming from python would either be CSV style, or JSON,
from these you can easily get labview datatypes.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(5,139 Views)
I get an array from the Data out in the form [1245, 2313,4144,1231,1231]. format string
(5,104 Views)
I would trim off the [ ] from the ends then use spreadsheet string to array with "," as the delimiter.
(5,083 Views)
