Pass reference into sequence
I'm passing a control reference to a slider to a subVI.  I placed the control reference of the subVI inside a flat sequence, but the reference value never shows up on the line when I run.  When I probe, I get "not a reference" returned even though the probed reference from the main VI shows just fine.  It's like the subVI control isn't wired to the connector pane (which it is by the way).
I moved the control reference in the subVI outside of the flat sequence and everything works just fine.  Why does putting it inside the sequence hose things up?
(2,931 Views)
It shouldn't, so something is wrong. Can you attach a simplified version of your code that shows the problem?
(2,929 Views)
Dumb mistake.  I re-initialized everything at beginning. once out of the sequence, it gets the value rather than re-initializing to nothingness.  Simplied VI led me to that conclusion so thanks.
(2,919 Views)
