Pass struct by value
Hi
Sorry for duplicating this topic repeadly, but I need assistance.
I am trying to call a function OpenPort in Dll that has a struct on the input, as shown below
extern uint8_T        (_stdcall *RMsys__OpenPort)(uint8_T, uint8_T*, uint8_T, TPortComParams);
typedef struct {
  uint32_T       TimeOut;
  uint32_T       OpenDelayTime;
  uint8_T        StopByte;
  uint32_T       BufferSize;
  //-------------- RS232 -------------------------
  uint32_T       Baud;
  uint8_T*       Parity;
  uint8_T*       Handshake;
  uint8_T        DataBits;
  uint8_T        StopBits;
  uint8_T        StartByte;
  //-------------- IP Based Connection -----------
  uint8_T*       Host;
  uint16_T       Port;
  uint8_T*       Protocol;
  uint8_T        HostMode;
  //-------------- Proemion Based Connection -----
  uint8_T*       //-------------- CANlink GSM 2xxx and 5xxx -----
    UserName;
  uint8_T*       UserPassword;
  uint8_T*       DeviceIMEI;
  uint8_T*       DevicePassword;
  //-------------- CANlink GSM 5xxx --------------
  uint8_T*       UsrMyEMail;
  uint8_T*       UsrAppName;
  uint8_T*       WebServiceIP;
  uint16_T       WebServicePort;
  boolean_T      UseWindowsProxy;
  uint8_T        AppProxySet;
  uint8_T*       AppProxyIP;
  uint8_T*       AppProxyUsrName;
  uint8_T*       AppProxyUsrPwd;
  //-------------- VCI Driver --------------------
  uint8_T        CANidType;
} TPortComParams;
Passing structure by value can be accieved in LabVIEW simply by passing every parameter individually (http://forums.ni.com/t5/LabVIEW/Interface-dll-function-with-struct-in-LabVIEW/td-p/1490848/page/2), therefore this I tried to do. I've configured each number as a proper number and passed by values, strings are passed as an arrays of U8 (Array Data Pointer), and they are never empty, as there is always some text on each input, and a boolean I am passing as an I32 (I have 64-bit system, but I am using a 32-bit LabVIEW version, besides, I tried also 64 bits). You can see a code below.
Can anybody give me any suggestions, about what is wrong in here? I have already run out of ideas.
Thank You in advance for any help.
Best regards
Barbara
Message 1 of 11
(5,392 Views)
What is the indication that it's not working? Do you get any errors? Have you checked the error out terminal from the Call Library Function Node? Does it make a difference if you configure the Call Library Error Checking level to Maximum?
Message 2 of 11
(5,373 Views)
Won't solve your problem, but you may want to right-click the CLFN and show the names of the parameters.
Message 3 of 11
(5,371 Views)
Hi
Thank You for an interest.
When I turned of an error checking, LV crushed completely:
Always, when I am trying different configurations, I receive the same error:
This is my function with names shown:
In addition I am attaching a result C code file constructed by default by LabVIEW from dll.
Any ideas?
Message 4 of 11
(5,353 Views)
Error checking set to Maximum makes no difference. You can see a dll configuration in attachement.
Message 5 of 11
(5,349 Views)
There is a good example that ships with Labview. Found here: C:\Program Files\National Instruments\LabVIEW 2012\examples\dll\data passing\
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 6 of 11
(5,330 Views)
Thank You aCe for pointing this example. It is really great. Unfortunatelly, all of the structures are passed to dlls by references in there, so I cannot use it. Still, it gave me new ideas for troubleshooting. As I am assuming, that either boolean value either strings a causing an issue, I played with and tested all of the combinations, that I could think of (see below). Still, I am not capable of calling this function. Can anybody please think of something else I could try? Any suggestions are welcome.
>>     Boolean     - adopt to source    - handles by value
    >> string     - String            - C string pointer            No
    >> string     - String            - C string handle pointer    No
    >> string     - String            - String handle                No
    >> string     - Array                - Array Data Poiter            No
    >> string     - Array                - Array Handle                No
>>     Boolean     - Numeric I32        - Value
>>     Boolean     - Numeric I16        - Value
>>     Boolean     - Numeric U8        - Value
Message 7 of 11
(5,319 Views)
Are your strings null terminated?
Message 8 of 11
(5,309 Views)
You may need to manually allocate/deallocate the memory for your strings. I had to do this with a DLL I worked with. There are three LabVIEW VIs that may help. They are DSNewPtr.vi, GetValusByReference.vi and DSDisposePtr.vi. You can find them in vi.lib\utility\imports. They are not documented anywhere but they are fairly self explanatory. If you need to set values into these memory blocks you can use the kernel32.dll:RtMoveMemory call to do that.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 11
(5,300 Views)
That's probably exactly the problem.
The easiest way to fix this is to configure the CLFN to pass all the strings as C strings. From the DLL's point of view it's still receiving a pointer to an array of U8, but LabVIEW will add the null termination automatically.
Message 10 of 11
(5,290 Views)
