05-09-2025 05:43 AM
Sorry! My bad. I should have elaborated.
I wanted to ask how to pass a cluster which contains nested clusters inside of it to a dll.
What should be the C struct be like.
05-09-2025 05:54 AM
Something like that:
According C Code:
#include "extcode.h"
#include "lv_prolog.h"
// Define the structures
typedef struct {
double X;
double Y;
} ClusterC;
typedef struct {
int N;
ClusterC C;
} MainCluster;
#include "lv_epilog.h"
void ProcessCluster(MainCluster* cluster, int *N, double *X, double *Y)
// Access the elements
*N = cluster->N;
*X = cluster->C.X;
*Y = cluster->C.Y;
be careful with alignment in 32-bit environment.
05-09-2025 07:36 AM - edited 05-09-2025 07:46 AM
Sorry but this sounds weird. You want to ask about what C code you have to write to interface a certain LabVIEW data structure to C and have basically no good understanding of C?
If a cluster matches with a struct, why would a cluster within a cluster be anything else than a struct within a struct?
Having no understanding of C is even bad if you just want to interface LabVIEW to existing C code, but the other way around is just insane.
But there is a little trick that you can use if you still insist on that:
- Create your Shared Library Node with all the data types correctly connected to the terminals
- Right click on the node and select "Create .c file...'
- Enter a name in the file dialog to write into
- Open that file afterwards
05-09-2025 07:43 AM - edited 05-09-2025 07:45 AM
Correct use of the includes lv_prolog.h and lv_epilog.h around the declaration of the relevant data structures, as shown in your example, takes care of that.
And if you use the "Create .c file..." trick explained in my other post, it is done automatically for you.
