Passing String to LABVIEW DLL via Python 3.3.2 version (Please help...)
Hi there,
I have a problem passing string to LABVIEW DLL via Python.
Basically, Input as a STRING from Python i.e “INIT” or whatever. Then pass it into LABVIEW then Output read as “INIT” from Python. But, what I read is nothing at the moment.
Python code as below,
from ctypes import *
from sys import exit
X = ('INIT')
STATE=c_wchar_p(X)
CallDLL = cdll.LoadLibrary("C:\Python33\\DLLs\\String.dll")
Output = CallDLL.String
OutputString= Output(STATE)
print ("String:",OutputString)
exit()
This is a result I am getting see below,
String: 0
Traceback (most recent call last):
File "C:\Walter\Pyhton_Examples\Math\String.py", line 15, in <module>
exit()
SystemExit
I have attached Labview code.
(3,295 Views)
I don't know Python, but as far as I can tell you're not calling the DLL properly. You configured the DLL to have 3 parameters (string input, string output, and output string length) and no return value. It looks like you expect the output string to be in the return value, which won't work because there is none. You need to preallocate space for the output string, then pass a pointer to that preallocated string along with its length as parameters to the DLL call. The DLL will copy bytes from the input string to the output string.
(3,278 Views)
