Passing a LabVIEW 2D array to an LPVOID pointer of a DLL
Inside my LabVIEW code I have a 2D array of U8 that I need to pass to a windows DLL.
The DLL is expecting the data as a continous block of memory by means of a void pointer.   (LPVOID pBits)
I cannot immediately connect the array to the Call Library Function Node.
This will give me the error that I cannot connect and array data type to an element datatype.
I also believe this approach is wrong since I do not know how LV arrays are managed internally. The probably have some internal housekeeping stuff like the dimension size in both dimensions.
So the question is: How do I connect the 2D array to the void pointer of my array?
The void pointer expects the data from the array to be a continuous block of data.
Thanks in advance for all the help!
(2,909 Views)
Hi Noxus,
If you configure the CLF to accept an array for this parameter, the CLF will pass a pointer to the beginning of the data.  In LabVIEW, resize the 2D array so that it's 1D, and in the DLL, expect the data in row-major order.  That is, if the Array is 5 rows by 3 columns, then the first three elements of the resized array would represent the first row.
I think the DLL ('C"?) uses the same row-major memory organization as LabVIEW for multi-dimensioned array-data, it's possible you can access the second element of the first row as:
pBits[0][1] - assuming the 2D array "pBits" has been dimensioned identically as the 2Darray in LabVIEW.
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,881 Views)
