Passing a boolean between loops
Right now it would be my understanding, through experience, that labview won't less you pass a boolean between loop. For example, a while loop contains some code that produces and true boolean, and this while loop also contains a case structure with a for loop inside of it, so the for loop is nested in the case structure which is nested in the while loop. Is it correct that in labview you can't pass this true boolean to the case structure to execute the for loop? Or am I doing this wrong or in a way that harder than it needs to be? I'm new to labview, more similar with Java.
Message 1 of 28
(5,826 Views)
You are probably doing it wrong because of misconceptions about dataflow.
I recommend to post a simplified version of your code (VI or at least a picture).
We are not good at reading and understanding long text description. Too ambiguous! 😄
Message 2 of 28
(5,811 Views)
Yes, sorry for not posting code, I know how much more helpful it is. Right now I am unable to though, hopefully I can post some fairly soon. It is fairly simple code though but I definitly understand
Message 3 of 28
(5,806 Views)
This is what you describe.  Anywhere close to your example?
aputman
Message 4 of 28
(5,781 Views)
Yes thats exactly it, thank you for replicating it. The true value doesn't seem to trigger the for loop however, is that normal? Or do I have some logic wrong?
Message 5 of 28
(5,774 Views)
Is your for loop in the TRUE case or the FALSE case?
aputman
Message 6 of 28
(5,764 Views)
This cannot be "exactly it". Please show your actual code.
How long does the FOR loop take to complete?
Message 7 of 28
(5,744 Views)
I would like my FOR loop to run when the boolean value returns a true to the case strucuture.
Message 8 of 28
(5,724 Views)
I am unable post my code now, but will try to in the near future. If you mean how many iterations the FOR loop will run, it's really undecided at the moment, most likely about 5 or 6 iterations.
Message 9 of 28
(5,723 Views)
The actual time is of course just dependent on the iterations chosen
Message 10 of 28
(5,714 Views)
