Passing a command to another application using Labview
Hi All,
I have a query. I am using two softwares for my experiment. I am calling coboldpc from Labview. What I need to do is when I call cobold pc from Labview, as soon as coboldpc opens it should start executing new.ccf file. I am able to call coboldpc from labview . How can I pass a command 'execute new.ccf' to coboldpc by using Labview! Thanks a lot in advance to the person who has answer to this.
Maithili
(3,177 Views)
Did you ever get this working?
Ben
(3,177 Views)
not yet
(3,177 Views)
Remind me,
Was there a DOS command line available for coboldpc?
Ben
(3,177 Views)
I do not know what do you exactly mean by this! I tried to execute coboldpc application through dos prompt and also to pass the command. It works fine with document file but not with an executable file. Coboldpc has a command line where I think I need to pass the command.
I am trying for one more option to work this out. I am trying to call coboldpc dll through labview. Actualy it i staking time to study those dlls written by someone else. I am not getting much of it. Do you have any idea by any way how can it become easier to use this option!
Thanks ,
Maithili
(3,177 Views)
