I am passing a large 3D-Array of type I16 to a sub-vi node of same type, and back to the main VI. For test purposes I have removed all processing in between. Still, the sub-vi call requires many ms to s, depending on array size. I was under the impression that variables are passed to sub-VIs by reference. Is this incorrect? can it be fixed?
Johannes
