Passing an Array of Clusters from LabVIEW to a DLL.
I have to pass array of structures to function in DLL. Attached is the VI i have created.
I am using "call library function node" to send parameters to DLL function.
In configuration of "call library function node" for array of clusters i have selected "Adapt to type" for type,
"Pointers to handles" for Data format.
With the above configartion its not working.
When i searched in web i found this below link
http://digital.ni.com/public.nsf/allkb/5FE3C48E8E1C3D018625722900681AF6?OpenDocument
As per above link i should get the option to choose "Array Data Pointer" from the Data format pulldown menu.
But i am not getting that option in type "Adapt to type" hence i have selected "Pointers to handles".
I am using labview 7.1Version.
In attched example parameter pMsg is a array of clusters.
(2,493 Views)
(2,485 Views)
