Passing array to Python Node
I need to pass an array to the Python Node in LabVIEW 2018. However it always gives the following error
How can I use arrays in the python script? I also found this forum post about a similar problem, but it was not solved.
(5,047 Views)
Sorry, the .py file was an old wrong version. This should be the correct one.
(5,029 Views)
I try your python code, the y = aa[1] = aa[2] just don't make sense to me. I think what you mean is y = [aa[1],aa[2]]. Another thing is the function name array() is just fishy.  So i fix all that and it is working now.
(4,874 Views)
