Passing array to call library function running on VxWorks (cRIO)
I am using a cRIO 9012 running VxWorks.
I have a Call library function VI in my application and I want to pass arrays of doubles to this function.
The problem is that I can not access the values in the array.
Here is the source code of my function:
#include "D:\\Programme\\National Instruments\\LabVIEW 8.5\\cintools\\extcode.h"
double avg_num(double *in1, double *out1)
    double ret;
    ret = in1[0] + out1[0];
    return ret;
The value of in1[0] and out1[0] is always.
When passing no arrays but single values, all is fine. But since my application is more complex than this example, I need to pass arrays.
The block diagram and parameter specification is as shown in the attached screenshots.
I am compiling the source code with the Gcc 6.3 which is available here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4puCAA&l=en-US
What am I doing wrong?
Or is passing arrays not supported on cRIO?
Maybe the makefile needs to be modified?
Thank you.
Christian
(2,914 Views)
I guess I have solved the problem.
The key was to set the parameter "Minimum size" for all function parameters to <None>.
Having this, I can read the passed arrays. I do not know why this works but at the moment, it is ok for me.
Thank you all.
(2,899 Views)
