Passing ctlRef from one loop to another
Is it possible to pass ctrlRef from one While loop to another??  I want to have the value of  crtlRef of an evet case in a while loop in another while loop. See the attachment.
Any way to do it?
Nghtcwrlr
(2,973 Views)
Just wire it into a queue (I see you know about those)
(2,967 Views)
How is it that actually? When i connect the CtlRef to parameter input of QMH Add Message to Queue.vi, it shows connecting different types. Couly you please give me a tip?
Nghtcwrlr
(2,942 Views)
Ok.. i just found another way....... I just created a CtlRef indicator in the first loop and then created a local variable in the other loop and linked it to CtlRef
Nghtcwrlr
(2,915 Views)
