Passing data from one VI to another
I would like to know is it possible to pass data from one VI another VI?? What I would like to do is to use the value pf measured "RPM" and pass it to my control motor VI.
As attached is my sample of VI
- sensor VI
- control VI
fendy
(3,878 Views)
You need to take some of the free LabVIEW tutorials of you don't know how to pass data to a subVI. The best way is through the connector pane of the subVI. Connect the controls of the subVI to it and you are done.
(3,872 Views)
You can find links to many of these free LabVIEW tutorials (which will completely answer your question) by looking in the upper right corner of the Forum's page.
Bob Schor
(3,854 Views)
you can pass data between vi's through references  Smiley Wink
(3,826 Views)
