Passing date and time to graph
I have problem passing the date and time to graph. i attached the pic whr it seem like not ok. need help..plz thk u
Message 1 of 8
(3,879 Views)
Please don't text message.  If you are at a real computer keyboard, there is no reason you can't use all the keys.
What problem are you having?  The picture you posted seems okay.  Please provide more detail and post the actual VI if necessary.
Message 2 of 8
(3,875 Views)
Sry i attached the vi and the text
Message 3 of 8
(3,873 Views)
this is extra vi's that needed sry forget to attached with the main vi.
Message 4 of 8
(3,870 Views)
Seeing the VI's didn't help me any.  They are way too large, and local variables and value property nodes are being abused.  Many of those are just pointing to hidden controls/indicators on the front panel.  Please don't use hidden controls as a substitute for a variable in a text based language.
Your VI doesn't show what the issue is the graph.  Perhaps you could post a screenshot of the graph with real data in it.  Even upload a VI that has been run, Edit/make Current Values Default, then saving and uploading that VI.
Message 5 of 8
(3,823 Views)
We need our own version of a sad Sarah McLaughlin song, like the ASPCA.
Richard
Message 6 of 8
(3,819 Views)
jeyanthi,
Your first post is just waht should happen. The timestamp is converted to a DBL. So what's the issue?
Richard
Message 7 of 8
(3,812 Views)
Hey jeyanthi,
It is unclear exactly what is going wrong in your system. It appears that you are simply reading from an excel file and then creating your own time stamp. So, an error in the time stamp that you would see would likely be due to the data you are reading in and assigning to the time stamp. Also, the title on your graph indicates that the data starts on 1/3/09, and that is what is indicated in your picture. So the question then, becomes what is it that you are expecting and what makes you think that it is not working properly?
Hope this helps,
-Ben
Hope this helps.
-Ben
WaterlooLabs
Message 8 of 8
(3,784 Views)
