Passing parameters to/from dynamically loaded VIs
Thank's this link works. No I can start my training
Message 11 of 13
(1,089 Views)
Accepted by topic author webu007
I had a personal meeting with webu007 today.
The problem with not understanding Ben's VI beside the German version was the fact, that he uses LV 8.0/8.2. In this versions the oldstyle Set/Get Ctrl Value methods using Typedescription and String are availble to select for the method. At this point he didn't know which primitve to use to convert any LV type to typedescriptor and string.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 12 of 13
(1,046 Views)
Thank's for clarifying my real problem. I think I understand now the principles of parameter passing to dynamically called VIs
Message 13 of 13
(1,028 Views)
