Passing pointer-to-pointer matrix
Can Labview pass to an external Dll-function a pointer-to-pointer format matrix (i.e. int ** or double **)? If so, how? If not, how could I possibly work around?
(2,960 Views)
No LabVIEW can't, because this declaration is not clear. Is it just a
pointer to a pointer to some memory or is it a pointer to an array of
pointers? While C's declaration doesn't make a difference between those
two the implementation is completely and utterly different. While the
first would sort of be possible to deal with in a standardized way the
second isn't as you have all sorts of uncertain things which are
implementation specific.
The simplest and proper solution to deal with this is having a wrapper
DLL which translates between LabVIEW datatypes and those complica
ted DLL
datatypes.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,960 Views)
