Passing the filter parameters to the FIR Compiler Xilinx IP on Labview FPGA
In my current application I want to implement a low pass filter using the FIR Compiler Xilinx IP . In the current application I need to pass the filter parameters from the PC onto the FPGA (which includes the parameter like pass band range , stop band range , sampling frequency etc.) as the filter specifications need to be dynamic based on the incoming signal and I cannot set fixed/static filter parameters. Could you please suggest an approach to implement this.
I checked across various blogs but could not find a relevant solution to the issue.Please let me know if you need any additional details .Any help about this  would be highly appreciated.
Thanking you.
Regards
Message 1 of 1
(2,602 Views)
