Passing values between VIs with different targets
I have two VIs, one under "My Computer" which is my main VI, and another under a DE FPGA target. I want to link these two such that the VI under the FPGA target will be the subVI, but it seems that whenever I place this VI as a subVI under the main VI errors show up. Any thoughts on how to solve this? Thanks.
(2,545 Views)
you can't use it as a sub vi, you have to communicte between the two using a DMA FIFO. hope this helps
Rodéric L
Certified LabVIEW Architect
(2,529 Views)
I've already found the solution by using FPGA interface functions, thanks for your help by the way Smiley Happy
(2,519 Views)
