Password characters in text box
I have just started , so my question might be a little naive....
I have a data acquisition VI which I want to password protect using the input dialog VI.
I am attaching a sample program.
Is there any way to hide the characters that are being entered as "*********" ?
Thanks.
Message 1 of 9
(6,976 Views)
You can hide the characters by selecting Password display of Control:https://www.ni.com/docs/en-US/bundle/labview/page/password-display.html
-If you don't event want to show the asterisk (*), i am not sure about this.
uday
Message 2 of 9
(6,972 Views)
Hi Uday,
Actually text box is not a control & does not have that 'password' option.
But anyway , I have been studying an old post where the solution has been provided by converting the express VI into normal VI.
Message 3 of 9
(6,955 Views)
Instead of using Express VI use your own sub VI with a string control and select the Password display by rightclicking on string icon.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 4 of 9
(6,953 Views)
The updated VI works......
Message 5 of 9
(6,948 Views)
Actually I want this to appear as a pop up when I run my main program , not as a control sitting there permanantly......that is the reason why I am using the dialog express VI.
Is there any way to make a string control appear as a pop up when I run my labview program....
Message 6 of 9
(6,944 Views)
Check this tutorial to make custom dialog boxes:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2BiCAI&l=en-US
uday
Message 7 of 9
(6,937 Views)
Accepted by topic author shantanu@india
call this vi in your main VI it will run as a pop up.
Message 8 of 9
(6,935 Views)
Thank you very much....
Message 9 of 9
(6,927 Views)
