Pasting Excel data into front panel table
Is there a method that allows a user to paste a spreadsheet snippet into a LV front panel table control?  My client has specified LV2009SP1 and I have a lot of data (more than 4 cols by 100 rows) that I would really like to not retype.
(7,444 Views)
Hi kc64,
This example should do what you want. All you have to do is change the 2D output array to a table control.
http://zone.ni.com/devzone/cda/epd/p/id/3177
(7,424 Views)
Thanks for your reply.  This example actually does not address the method that I seek.  Instead of pasting the data into the table, the example opens the Excel file and imports the data without ever using a front panel table control.  Any other ideas?
(7,396 Views)
kc64,
I do a lot of copy / paste and data interchange between Excel and LabVIEW.  When you copy data from Excel, it will be TAB delimited array data in a spreadsheet string.  This is easy to parse in LabVIEW using the spreadsheet string to array.vi.  To paste to a table, read the clipboard string, parse the string to an array, and write to the value property of your table.  See that attached 2010 vi and pictures.
-cb
(7,390 Views)
Many thanks for this solution. It works very well.
(6,778 Views)
That solution works from word tables as well.  Very handy.
Kudos for the neat trick.
(5,234 Views)
Awesome solution even 12 years later!
(3,619 Views)
