Patches 6.01 or 6.02 cause that you cannot not uninstall Labview anymore. You can not reinstall the original Labview6 either. BIG PROBLEM?!?!
You probably had no luck with uninstalling previous LabVIEW versions clearly. Ask NI for the cleaning utility and reinstall the all LabVIEW. I had similar problem.
Sergey
(2,943 Views)
I tried on several PCs, with win98, win2000 and winNT. The problem occured each time.
I did not have any previous version of Labview on these machines. But I'm very interested by the cleaning utility. I'm going to try to find it and download it.
Thanks very much.
(2,943 Views)
Start search from calling/e-mailing NI tech support first.
Good luck.
Sergey
(2,943 Views)
search kb for "transforms and you will find a solution, part of it is
:Solution: You must use the Registry Editor in Windows to fix this
problem. Please follow these steps:
1.Go to Start » Run and type regedit (or regedt32 on
Windows NT).
2.Navigate to HKEY_CLASSES_ROOT » Installer »
Products » 20F22BE295933D11082B000540F95DD5.
3.Delete the "Transforms" value in this folder.
4.Exit the Registry Editor.
5.Go to Add/Remove Programs and try the
uninstallation again. Once the uninstallation completes, reboot your
computer.
> PROBLEM?!?!
(2,943 Views)
