Path changed in Executable, screenshot impossible
Hello everybody,
I have a program, which save a screenhot of the current VI. If I create a executable the "save a screenhot of the current VI" doesn't work.
Maybe there is a problem with the file directory? I attempted it with the File constant: current vi path, application directory and default directory, but without success.
If anywhere a simple example or anybody have some links?
many thanks in advance
zäpfle
(3,128 Views)
Accepted by topic author zäpfle
I could solve the question, see the attachment.
 zäpfle
(3,121 Views)
I don't know what your solution is, since you don't show a "before" and "after". Perhaps you were encountering this well-known issue: Why Does My Executable Not Work When Using the Current VI's Path Constant?
(3,112 Views)
Thanks for your help.
zäpfle
(3,076 Views)
