Path control's browse cancel buton return value
Oh thanks for the enlightenment, dan_u! May I know the logic behind this club, I mean what's wrong with express VIs (this question was posted from educational/learning point of view. It is not meant to criticize.)!
Message 11 of 15
(860 Views)
Thanks dan_u! That certainly was informative (kudos to you). But I realy needed the info about the other button press (the cancel button) as I need to clear the file path being displyed in the path control (if user had typed one in before he hit the browse button) if he had choosen to click the cancel button.
Message 12 of 15
(859 Views)
Yes I agree about the File Dialog Express VI. Mighty useful VI.
Message 13 of 15
(857 Views)
OK I see. Then the file dialog is the better (although more complicated) solution I guess.
Well the thing about express VIs has been discussed in several threads. It kind of allows to program without understanding what's going on, it's more configuring than programming. Also, express VIs are (in most cases) less efficient than programming the functionality according to your needs.
Check e.g. this thread.
But as André said, there are a few useful express VIs. File Dialog is definitely one of them. And express VIs might come in handy to just do some quick testing.
Message Edited by dan_u on 04-16-2009 12:00 PM
Message 14 of 15
(852 Views)
Thanks dan_u, for the link. I'll certainly read it before expressing my views on Express VIs.
Message 15 of 15
(838 Views)
