Path for List Folder Function won't let me just select a folder, always a single file...
I put together the List Folder Function so I could search a number of files for a certain key word. But whenever I try to feed it the folder path, the usual path window comes up, and the folder with files are there, but I can't select just the folder. It always wants a single file. Anyone know a way around this?
(3,099 Views)
Can you share your code? You should be able to feed the "List Folder" function any path you like...
Is your input path a control on your front panel? You may have to do the following: right click >> Browse Options... >> Selection Mode >> Folders
(3,077 Views)
