Path to LabVIEW help files.
I'm working in an environment where ClearCase is used as version control system. We have also put the LabVIEW folder under ClearCase control to get the same environment for everyone working in the project. However, one little problem arises with this for us. LabVIEW can no longer access the help files. Whenever "Click here for more help" is used, the html help browser opens, and is directed to the right location in the tree, but the help window is blank.
I have some suspicion that this might be due to some security settings decided by the company, but I haven't found the setting or any way around it. My idea now is to try and point out the help files to the hard drive, and I was hoping that there might be an entry in the LabVIEW.ini file I could make to separately point out where the help files recide.
So my question:
Is there such an entry to make in the ini file, or is there any other way to get around my problem.
Regards
//Martin
Message Edited by M_Peeker on 08-10-2005 07:24 AM
CLA
https://www.prevas.se/expertis/test--regulatoriska-krav.html
(2,839 Views)
Hello!
The only supported SCC tools available for LabVIEW today is Perforce and Microsoft Source Safe but all SCC tools that are compliant to Microsoft’s SCC technology should work.
I couldn’t find any information regarding similar problems reported by customers using other source code management systems. I have also been looking for entries in LabVIEW's ini-file for paths regarding the help without any success. There exists a few external websites that contains information about possible ini settings but none of them mentioned what you were asking for.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,808 Views)
