Pattern Matching (cross correlation technique)
In pattern matching, it is used as algorithm of comparison cross correlation, my question is if its use with continuous or discreet data.
Greetings
(3,120 Views)
Hi Yadira,
I'm assuming you're using the NI-Vision pattern matching, correct? If so, the following documents explain how to use the pattern matching function and how the algorithm works.
How To Use Pattern Matching
Pattern Matching Strategies
Hope this helps,
Travis H.
LabVIEW R&D
(3,096 Views)
