Pause a timed task, do something, and than return
Hi all!
I am new programing on LabVIEW, and I have been trying to do something with no success.
Scenario:
User write a value to 'howLong' (should be around 9secs);
If the system turn 'request1' to TRUE, the action1 must stay TRUE for 9secs.
During this time, if the user presses the button request2 (Latch Until Released), action1 must be PAUSED while action2 is completed, and than it has to go back to action1 turning it back on until the 'actionTimer' goes to 9secs.
request1 turns action1 ON
request2 turns action2 ON
action1 must obbey the 'howLong' variable
action2 have to stay ON as long as the user keep pressing the button
action2 has priority
 Does anyone have a goood idea on how to do this?
Thanks a lot!
(3,066 Views)
No one here will do your homework for you (except for Ray R Smiley Wink).  I suggest you take some Labview tutorials (free and online at ni.com).  Make an attempt at coding. Then we could help you get over your problems.  To start you off, learn about elapsed time function, loops, case structures, event structures.
- tbob
Inventor of the WORM Global
(3,058 Views)
Please don't get me wrong.  I don't want anyone doing my things, really!
I have tried a lot of things during these days, but I haven't found anything so simple as I think it should be.
I just would like to hear some ideas from you guys, that are more experienced in LabVIEW.
Anyway, thanks for your time tbob.
(3,053 Views)
I'll tell you about some of the tools and how they are used.  Study the event structure.  Here you can put in some code to be executed when a button is pressed.  It sits and waits for an event (like a button pressed, which is called a value change, or a mouse move, etc).  When the event takes place, the code inside the event case will execute.  So you can create an event case for your buttons.  Inside the event case, you can start a timer and wait for it to finish.
The case structure is like and If-Else in text based languages, or more like a Select-Case in C.  Wire in some variable.  A case which matches the variable value is selected and the code inside that case is executed.
For you problem, you described a sort of algorithm, request 1 turns on action 1.  You can set up an event case for request 1.  Inside that case, put code to cause action 1.  Continue in this manner.  When you get stuck, post your code and tell us what you are having problems with.  Someone will help you for sure.
- tbob
(3,046 Views)
