Pause button in a For Loop
Hi everyone, i have some problems with the implementation of a 'Pause Button' for a 'For Loop'; I am using a QMH, in the 'consummer part' i am running 2 "For Loops" one inside the other, i found a way to pause a 'while loop', then i decided to do a simple VI to make sure if it is possible to Pause a For Loop with that idea, and the answer is 'yes', at the moment I use this idea in the main program, i realise when i wanna pause the for loop to see some details in a Table indicator, the button was not doing anything, as if it were not enable. Ty for your answers.
(1,648 Views)
If your purpose is to pause the program for debugging purpose, I would recommend using breakpoint instead. The only possible way of pausing a for loop that I can think of is by using a state machine while loop with indexing to mimic the behavior of a for loop.
(1,629 Views)
Your description is not sufficient to explain your problem. Please show us your VI.
(My guess is a dataflow issue. Why do you have FOR loops and why is one inside the other?).
(1,628 Views)
